Another Newbie Here...wondering the best way to learn color correction.
Postby mikemeister_admin » Tue May 08, 2007 8:23 pm
Hello all,
I work for a publisher that is looking for strategies of digital proofing.  We've got lots of possibilities on the table that mean bringing people in that have this skill.  If you wanted to put yourself into a position where you could do it yourself what would you do?
Thanks!
Alex
Postby ggroess » Tue May 08, 2007 9:30 pm
What kind of volume are we talking about??
100's per week??  1000's ?
Postby mikemeister_admin » Tue May 08, 2007 11:13 pm
To add to Greg's questions, I would like a little more detail about "digital proofing". Over the years I've heard that used for a lot of different things. If you would, please describe what you are really trying to do. This should include the type digital input and output that you are working from and to.
Thanks,
Clyde
Postby mikemeister_admin » Sat May 12, 2007 5:54 pm
Can't help you right this minute, but I am preparing to move to the Philippines where I will gather together a few technicians and teach them to color correct. I already have few experienced maskers. Because of the lower wages in the Philippines this sort of thing is easily outsourced.
What part of the process do you want to do yourself? If you are a printer you will want to get your printer profiled so that if you have files prepped elsewhere you can get predictable results. You will want to write a manual (PDF or website) with your specifications spelled out clearly.
You will want Dan Margolis's book on Professional Photoshop and you will want Curvemeister. Ask the Curvemeister himself, but it seems likely that you might want to make a set of pins that will work with your profiles.
