Oh My Stars
Oh My Stars
Postby gregmeister_admin » Wed Nov 27, 2019 8:20 pm
Hi,
Below is an image that a friend of mine helped create by making the 12 exp. of the galaxy.
I did the following to resolve the data from the originals.
1) I used Affinity Photo to create the stack and export a pixel layer as a PNG for processing.
2) Using a piece of freeware called RNC color Stretch I was able to create the base image.
2a) I used Affinity Photo to desaturate the Reds in the image about 15%.
3) Using Curves I expanded the brightness by adjusting in CMYK only the K channel i found it to be a much more subtle effect.
4) I used the NIK Dfine2 filter to reduce the color and luminosity noise.
5) I used Curves to enhance the saturation in LAB of the B channel.
Re: Oh My Stars
Postby Ganna » Thu Nov 28, 2019 8:37 am
Greg this looks great, worth the hours you worked on it
Re: Oh My Stars
Postby Tildy » Sun Dec 01, 2019 2:28 pm
How many hours...?
Re: Oh My Stars
Postby gregmeister_admin » Mon Dec 02, 2019 5:15 am
Actual Process time?? about 45 minutes.
Research and testing about the same.
