I have been playing around with Affinity Focus Merge and I find the process very straight forward and powerful
This image is a composite of 50 images from my Nikon. I applied the NIK sharpening pro 3 for output to the image. Very lightly.
Affinity Focus Stacking
Re: Affinity Focus Stacking
And Another:
Greg, did you mean 5 images?
nope 50
They look amazing. Was it a macro lens?
Yes. Nikon 105 Macro.
Used for Portraiture and Macro.
Portrature and macro. I will be interested to hear about this. Is it a special lens or could you just use a normal 105?
Great images.
I had a focus stack of a landscape. Unfortunately, it was a one time affair and I did not do enough images and the out of focus image of the subject was larger than the in focus. I had a large blurry "halo" that I had to hand crop out. Heavy sigh. That image will not be available to re shoot.
julie wrote:Portrature and macro. I will be interested to hear about this. Is it a special lens or could you just use a normal 105?
Julie, I think Greg is loafing somewhere
So...a macro lens has the capacity to focus at a very close distance -closer than a normal lens? But can also focus to infinity? Is this right?
Users browsing this forum: No registered users and 80 guests
