Assignment 1, example 6
This is the forum for the CM 101 Classes beginning January 2017
Postby Tildy » Fri Jan 13, 2017 2:26 am
Sorry, don't remember what I used as the neutral in this one, but it probably wasn't the sky :D
c01s01-Example6 tb.jpg (25.88 KiB) Viewed 20725 times
Sky set as neutral:
Re: Assignment 1, example 6
Postby gregmeister_admin » Fri Jan 13, 2017 8:31 am
Tildy,
Good job on this overall. You could probably open the mid-tones again just a touch. This is one of the last things I look at before I click apply in CM. I ask myself does the image fit the lighting and mood? Can I make it better? If it is yes and you are in RGB apply your change and then go back in with LAB and adjust the L channel.
