Beta-testing
This is the forum for the CM 101 Classes beginning January 2017
Beta-testing
Postby Tildy » Fri Jan 13, 2017 2:17 am
Hey Greg,
I'm going to use this thread to note anything I find confusing in the course, in case you want to clarify it for future generations :D
There's only one thing so far, and it may simply be that I'm an idiot rather than that it needs changing:
For the example images, you say: (right click above and “save as” for the original image download)
I did that, which is how I downloaded the tiny images. I figured they were supposed to be that size, as they were only examples. Art thought you probably assumed that any reasonable person would have first left-clicked on the images to see their full size. But it's worth keeping in mind that some people may not be familiar with how online forums work, so they may need each step spelled out :D
Re: Beta-testing
Postby gregmeister_admin » Fri Jan 13, 2017 8:20 am
Hey Tildy,
Thanks for the feedback...
All of the images are supposed to link back to a full sized image regardless of the image size on the page. I'll re-check these as the pages were rebuilt when I moved them to the class content software that we now use.
