Assignment 1
This is the forum for the CM 101 Classes beginning January 2017
Assignment 1
Postby Tildy » Wed Jan 11, 2017 3:14 pm
c01s01-Example3 tb.jpg (56.53 KiB) Viewed 32754 times
c01s01-Example4 tb.jpg (37.89 KiB) Viewed 32754 times
The parts that came out purple here were what I set as the neutral:
c01s01-Example5 tb.jpg (36.98 KiB) Viewed 32754 times
c01s01-Example6 tb.jpg (25.88 KiB) Viewed 32754 times
I'm not convinced by either of these, necessarily, especially the first one -- but it seems like you have to sacrifice some brightness to avoid the artifacts:
Re: Assignment 1
Postby Tildy » Wed Jan 11, 2017 3:16 pm
ps: Good job on accurately representing the colour of the polluted NYC sky :D
Re: Assignment 1
Postby Tildy » Wed Jan 11, 2017 3:51 pm
Er, sorry, I downloaded very small versions of the original images, ahem -- so I did these two again:
Would do the others over too, but it's late and my eyes are going :)
Re: Assignment 1
Postby gregmeister_admin » Wed Jan 11, 2017 7:03 pm
Tildy,
can you post these as separate threads so I can comment in line with you? I know it's more trouble but the end result is easier to relate to. For instance I want to work with you on the spheres and the Ellis Island images but do not want to mix the discussion as we cross communication paths.
Re: Assignment 1
Postby Tildy » Thu Jan 12, 2017 2:30 am
Ah, ok -- sorry, I can see how that could get confusing :D Am at work now but will do this tonight, and if there's time will re-do the other small images. I thought they were small because they were examples, but when I showed Art what I'd done he said they weren't supposed to be like that, which probably should have been obvious to me.
