Unable to test CurveMeister
sfleury
Postby sfleury » Thu Sep 24, 2015 6:06 am
Hello
Just discovered CurveMeister, downloaded and installed it
I understood that the Demo works only on Windows 32 bits - Am I right ?
I have a Windows 7 - 64 bits but installed CurveMeister demo anyway
I have several versions of Photoshop (CS5, CS6, CC, CC2014, CC 2015) but CurveMeister does not appear in any of them
Is that normal ?
How could I try CurveMeister ?
Thanks Have a good day
Postby gregmeister_admin » Wed Oct 21, 2015 8:51 am
I am so sorry we missed your posting.
The Demo works in All of the versions of PS you have listed. The plugin has to reside in the C:\Program Files\Adobe\Adobe Photoshop CXXX (XX Bit)\Plug-ins\Filters Folder in order to be seen by PS. In the later versions like CC2014 or 2015 it has to go in the required\plugins\ Folder.
I am checking to see if the Demo is 32 bit only I do not think it is. I'll verify with Mike.
Postby gregmeister_admin » Mon Oct 26, 2015 8:57 am
The Demo is 32 bit only at this time.
sfleury
Postby sfleury » Mon Oct 26, 2015 12:27 pm
Thank you for your answer
As all my computers run with Windows 7 - 64 bits, there is no way to try the demo ;-(
is there a way (a video ?) that shows how the product works and what it can do ?
Thnks for your help Have a good day
Postby gregmeister_admin » Wed Oct 28, 2015 9:45 am
CS5 and CS6 Both have a 32 bit version of the PS program that you can run. They are separate from the 64 bit installs and used to be installed by default unless you prevented them. Check your PC for the 32 bit version in C:\Program Files (x86)\Adobe\Adobe Photoshop CS6 If the Photoshop exe is there it is the 32 bit version.
Also...
Curves are easy video
There are also other videos on the Curvemeister YouTube channel.
sfleury
Re: Unable to test CurveMeister
Postby sfleury » Thu Sep 12, 2024 5:40 am
Hello
I'm back after many years
I currently use the last version of Photoshop, with Windows 10 Pro - 64 bits
I would like to test CurveMeister before buying it
Is that possible ? How should I roceed ?
T hanks for your help Have a good day
Postby gregmeister_admin » Fri Sep 13, 2024 11:11 am
There is a link under the Learn About the Forum discussion thread on the forum page for the 64bit demo version.
http://curvemeister.com/downloads/curvemeister3_product_FJK/Curvemeister3-64-3.8.2.exe
