Templates for colour plates
Davinci Resolve has a nice feature: an adjustable model of colour calibration plate (see the picture attached and video on their site). In terms of Curvemeister it should look like a set of pins attached to the flexible grid. Making such a template may be a good timesaver for people using custom plates and pinning dosen on colours each time.
- davinciresolve_color_plate (999 Bytes) Viewed 33075 times
We are very close to supporting this. If you can keep the color checker or other target in the same position, Curvemeister allows you to save a set of pins to fixed locations, load them onto a new image, and display deltaE values for each pin. If necessary, you can drag the pins around manually.
I wish it worked. I can Save sample points -> To File... and it saves a .edr2-file. But trying Load sample points always causes Photoshop to crash. I've tested both 32 and 64-bit of Photopshop CS6 and CC 2014. My OS is Windows 7 x64, no special restrictions are applied to the file.
One extra check: if the .edr2-file is blank, it reports Attempted to access an unnamed file past its end. It crashes only while reading "normal" sample point files.
But, to be fair, it's absolutely non-critical for me )
