new bug
Postby imported_julie » Wed Feb 25, 2015 3:41 am
I seem to have some sort of bug
Started the last few days
I can duplicate it mostly using CMYK with a mask and cyan adjustment
webscreen-shot-02-25-15-at-01-35-pm-jpg
webscreen-shot-02-25-15-at-01-35-pm-jpg (999 Bytes) Viewed 81211 times
Postby -default » Wed Feb 25, 2015 12:50 pm
OK, thanks Julie.  I'll try to recreate the problem.  Can you give me the size of the image in pixels, and also your version of Curvemeister and Photoshop and whether you are 32 or 64 bits?  Thanks.
Postby ggroess » Wed Feb 25, 2015 1:28 pm
What mask were you using??
Postby imported_julie » Wed Feb 25, 2015 9:09 pm
I will give all the details when I get home from work.
Greg I think it was a b mask.
I was trying to isolate the sky
I could make it happen again but not consistently
Postby imported_julie » Thu Feb 26, 2015 9:02 am
Image size 4288 x 2848 pixels
Adobe Photoshop Version: 13.0.1 (13.0.1.3 20131024.r.34 2013/10/24:21:00:00) x64
curvemeister3 v 3.8.2
hope this helps
Postby imported_julie » Thu Feb 26, 2015 9:04 am
Hi just did it again using a reversed b mask
Postby julie » Sun Apr 26, 2015 3:10 am
I'm noticing it again
only seems to occur when using CMYK and a mask
This was a hue mask but as you can see from the above it has happened on another mask
I have included a screen shot showing what happens
The square is always in the same place
screen-shotweb-04-26-15-at-06-03-pm
screen-shotweb-04-26-15-at-06-03-pm (195.13 KiB) Viewed 81211 times
Postby julie » Sun Apr 26, 2015 4:20 pm
I just made the sky purple to demonstrate the bug.
It's not what I would have been aiming for
I regularly use CMYK and a mask to remove some cyan from skies
Also it's not visible in CM only when saved to PS
Postby mikemeister_admin » Mon Apr 27, 2015 3:34 am
Hi Julie.
Does this problem happen every time?
Thanks.
Postby julie » Mon Apr 27, 2015 4:31 am
Yes but not with every mask. I was able to go back into cm and repeat this to send to you. The original correction was a much more subtle blue
