Right-hand third of CM 3.8.2 preview window went black...
FujiMan
Postby FujiMan » Fri Nov 21, 2014 10:00 am
...and I can't figure what I did or how to undo it. It remains black even after I've exited from Elements and then started up the program again. The image is still "under" the black area, because when I move the cursor around on it, I can see the clock reacting.
A diagnosis and a cure would be much appreciated!
Thanks!
Fujiman
Postby ggroess » Fri Nov 21, 2014 3:07 pm
Can you post a screen shot of the issue and tell us more about how it happened.
You can un-install and re-install the plugin and choose re-set settings to see if that makes it go away.
Users browsing this forum: No registered users and 63 guests
