cc 2014
Postby sjordan93436 » Sat Sep 20, 2014 12:55 am
I was fooling with CC 2014.  I installed it manually no problem.  Image two is the same file at CMD 0.  Weird anomoly.
screenshot001-jpg-2
screenshot001-jpg-2 (999 Bytes) Viewed 58431 times
screenshot002-jpg-2
screenshot002-jpg-2 (999 Bytes) Viewed 58431 times
Postby ggroess » Sat Sep 20, 2014 12:43 pm
Steve,
Can you give me more info on what your steps were?
I have had almost no issues with CC..
Postby sjordan93436 » Sat Sep 20, 2014 2:57 pm
In the adobe CC 2014 folder, I pasted int the filter folder and the curvemeister3.8bf.  Adobe has two sets of folders for CC and cc 2014.
I too have had no problem with Adobe cc and installing CM.  I will try later today doing the auto install.
Postby ggroess » Sun Sep 21, 2014 10:54 pm
So is this more of an anomaly?  or is this repeatable?
Postby sjordan93436 » Mon Sep 22, 2014 12:07 am
Yes, every time. I turned off video acceleration, no change.
Postby ggroess » Mon Sep 22, 2014 3:56 pm
I'll make sure Mike sees this...Thanks!
There have been a few other video type issues as devices get better screens.
Postby sjordan93436 » Mon Sep 22, 2014 5:46 pm
I have another more recent anomaly from CC 2014, not CM this time.  I get a column or two or three of transparent pixels running vertically down the image imported from ACR.  I tried the same images in CS6, no problem.  I am installing a new video driver to see if that helps.  Th streaks are only visible in cc 2014.  Weird.
Postby ggroess » Mon Sep 22, 2014 6:50 pm
I'd go check out the CC forums and see if others are in the same boat.  Usually when display problems are present they are happening for more than one person.
