I have installed PsCC2014 and several previous plugins do not work so no great hurry to install all my add ons.
But plan to use CM in PsCC2014. Anything new or special knowledge needed? Or can I copy the PsCC .atn for my CC keystroke activation to enable CM in PsCC2014? or do I need to start again and do 2014 like CC?
Doug.S
PsCC2014
With your words of encouragement...I took the plunge.
Installed CM3-64-3.8.2 per the .exe installer into CC2014
Opened CC2014 and it was there.
Since I had imported my presets from CC when I installed CC2014, the shortcut key .atn was there and it worked.
Tested a file and the round trip back to CC2014 worked as usual.
Since I use two monitors, all I needed to do is drag the curves window to other monitor and make it big...works like PsCC.
So I am in business for CM in PsCC2014.
easy peasy
Doug
easy peasy
Doug
Users browsing this forum: No registered users and 63 guests
