Update not working (correctly)?
pedroluis
Postby pedroluis » Wed Mar 19, 2014 9:06 am
Your newsletter august 2013: The easiest way to upgrade is to use the upgrade command, available from Start>All Programs>Curvemeister.com>Check for Updates.
No. This is somewhat corrupted. See screen dump of pop up message attatced.
curvemeister-update-failes-jpg-5
curvemeister-update-failes-jpg-5 (999 Bytes) Viewed 32873 times
Postby ggroess » Wed Mar 19, 2014 12:21 pm
I'll forward this onto Mike Russell.  You might want to down load the latest build from this forum link
http://www.curvemeister.com/forum/index.php?action=downloads
Postby -default » Thu Mar 20, 2014 1:14 am
Yikes - this is normally a function of the folks who provide the installer - I wonder if they are off the air.
Thanks for the note.  In this case, the updater does not need to be updated, so the rest of the install should be fine.
