Week 2 Link.
This forum is for the 201 Class preview testers and discussion.
dazza17
Postby dazza17 » Mon Jul 14, 2014 1:17 am
Hi Greg
After watching the Video it occurred to me the Blend if sliders on a layer are another way of pulling back the light and Dark ends of the adjustments
Cheers Daryl
Postby ggroess » Mon Jul 14, 2014 1:16 pm
Daryl,
Would this not clip the historgram?
I have not really played around with it but How would you know if you took out too much?
I'm not challenging I'm trying to understand this better.
dazza17
Postby dazza17 » Mon Jul 14, 2014 11:12 pm
"re Daryl,
Greg"
Its quite hash the sliders if you don't split them by holding down alt to separate the sliders to create a gradual change.
I have seen Dan us it to separate a sky by changing the Blind-if to Blue and using alt that feather the edge.
Postby imported_artmar » Wed Aug 13, 2014 4:53 pm
The "Changing the Channels" video link in Chapter 2 seems to be not be working.
Postby ggroess » Wed Aug 13, 2014 5:47 pm
Please try it again.  I re-built the link and tested on my end.
Some of the Page formatting is messed up and it will need a review.
Postby imported_artmar » Wed Aug 13, 2014 9:17 pm
No, still not working on my end unfortunately.
No problems playing the highlight and shadow control videos.
Postby ggroess » Wed Aug 13, 2014 10:59 pm
Art is the link active?  If not, you have a cached version of the page and need to refresh the page after it loads.
If that does not fix it try clearing your cache in your browser.
Postby imported_artmar » Wed Aug 13, 2014 11:38 pm
I've cleared the cache and it's still not working.
Here's a screen grab of what I see after I click on the link in the text.
The circled arrow in the upper left hand corner is not active.
curvemeister-link-jpg-7
curvemeister-link-jpg-7 (10.91 KiB) Viewed 13414 times
Postby imported_julie » Thu Aug 14, 2014 12:27 am
Thought I would check.
Same thing happening as Art.
Same screen.
Cache cleared and page refreshed.
Postby ggroess » Thu Aug 14, 2014 2:10 pm
Here is what I see in my browser...(chrome)  I get the same results in I.E. which I never use...
See screenshot.  The Arrow is pointing to the text that is a hotlink.  I'll add the link to the Icon as well.  Good Catch...
capture-jpg-14
capture-jpg-14 (79.61 KiB) Viewed 13414 times
