Since Greg did all the hard work on this image, I decided to start with his corrected version and have a go at the floor (okra, or thereabouts), and fine-tune the walls.
This image will always be a work in progress I think.
Revisiting Malta
I changed the hue in HSB, and then used a layer mask to brush it onto the floor. I conservatively used a lighter color; the version attached, for example, with a more deeply saturated hue, looks better to me in some respects. But I don't know if it's correct.
Julie, is this getting closer to what you saw, or would like to see? Also, what about the colors at the bottom of the rear wall -- are the colors there in this version "real" or artifacts.
- malta_6-jpg (299.71 KiB) Viewed 32612 times
