Curvemeister is windows only. Mac's ship with boot camp. Parallels is available. Does anyone have experience running Photoshop under Mavericks? Is the performance okay.
I have a new Macbook Pro and plan to use it on the road mostly, keeping my windows desktop for heavy editing.
Photoshop and CM under Mac
A quick update on CM / bootcamp / CS6. CS and CM run on the macbook pro under bootcamp. Adobe does not understand that all high resolution monitors are not large. The icons and text with the high resolution monitor look tiny. CM does fine.
There was a glitch in installing CM on the computer. I do know if this is a windows 8.1 or bootcamp issue. When you run CM installer, it cannot find photoshop and you cannot browse to find it. Explorer shows the c: partition under a bootcamp label. So install. Exit install. Find the cm filter file. Copy to bootcamp .... photoshop cs6/plug-ins/filter and it works. You might have to add the filters subdirectory.
Onward and upward.
Onward and upward.
