This one is similar visually but behaves differently upon correction. Once the Blue cast is gone the trees are lifeless and drab...
Shot 1 below is a BTN correction. Once I got it really close to where I wanted it the sky was an odd color so I used the Glenco Sky pin. It seems to have made it look better but that is a subjective call. I ahve attached the ACV file if you want to load it...
Shot 2 is adding a Saturation boost in LAB by adjusting each Color Channel separately. I added more Green Magenta than I did Yellow Blue.
Tina - Mountain Scene 2 From E-mail
- capture-jpg-21 (999 Bytes) Viewed 20461 times
- capture2-jpg-8 (999 Bytes) Viewed 20461 times
- gg100621_629_0483_4_5_6_7-jpg (999 Bytes) Viewed 20461 times
- 100621_629_0483_4_5_6_7-rgb-acv
