sliders gone
Postby imported_julie » Sat Oct 26, 2013 6:48 am
I just upgraded to 3.8.2 and the sliders have disappeared.
Do I need to reinstall?
Postby ggroess » Sat Oct 26, 2013 4:17 pm
No julie you should be able to make them show from the ribbon tools.  There is a little down arrow next to button and in the menu check the menus you want to see.
capture-jpg-24
capture-jpg-24 (43.78 KiB) Viewed 36555 times
Postby -default » Mon Oct 28, 2013 10:04 am
Thanks for fielding this one, Greg.
If this does not work correctly, then do a remove and a re-install and ask Curvemeister to reset your user interface settings during the install.
Postby imported_julie » Tue Oct 29, 2013 1:47 am
thanks
all working now
