Color Pins
This the forum board for The Curvemeister 101 class starting August 25th 2013
tmanley
Postby tmanley » Sun Sep 15, 2013 10:36 pm
Week 3 talks about Color Pins with these directions:  Curvemeister provides a number of pins by default, and there is a library of pins, located in the Goodies folder,(On my system they are located in the local folder C:ProgramDataCurvemeister.comCurvemeister3-64Swatches) that you can add to your working set. Copy the Text files from the Goodies Folder to the Swatches folder and re-open Curvemeister.
I haven't been able to find that file.  Could it be somewhere else?
Thanks,
Tina
tmanley
Postby tmanley » Sun Sep 15, 2013 10:43 pm
I found them online and have downloaded the files, but where should I put them?
Thanks,
Tina
Postby ggroess » Mon Sep 16, 2013 2:53 pm
Hi Tina,
They go in the Program Data folder located here:
You might have to turn on the hidden folders feature in the file manager to see this folder.
See screen shot below.
capture-jpg-26
capture-jpg-26 (80.84 KiB) Viewed 8846 times
tmanley
Postby tmanley » Mon Sep 16, 2013 3:46 pm
That was exactly the problem!  I couldn't find that folder anywhere.  Thanks, Greg.
Tina
