Tree Trouble
Postby ggroess » Fri Aug 30, 2013 3:34 am
Ok,
This one needs something...
Give it some love...
gjg_0067-jpg
gjg_0067-jpg (999 Bytes) Viewed 46894 times
tmanley
Postby tmanley » Fri Aug 30, 2013 3:04 pm
This one was hard!
tinagjg_0067x3-jpg
tinagjg_0067x3-jpg (305.05 KiB) Viewed 46894 times
Postby sjordan93436 » Fri Aug 30, 2013 9:30 pm
Is it too late for an alumni to post?
gjg_0067sej-jpg
gjg_0067sej-jpg (198.79 KiB) Viewed 46894 times
Postby ggroess » Sat Aug 31, 2013 12:48 am
Steve,
Is there some calibration issue going on?  My laptop screen shows your stuff as kind of blue....
Postby ggroess » Sat Aug 31, 2013 12:49 am
This one was hard!
Overall very nice correction...you lost the highlight details see screes shot1 "mine" and 2 yours below.
greg1-jpg
greg1-jpg (154.85 KiB) Viewed 46894 times
greg2-jpg
greg2-jpg (191.3 KiB) Viewed 46894 times
Postby sjordan93436 » Sat Aug 31, 2013 3:19 pm
This was done with my laptop.  I avoid any colorful corrections with it.  I was frustrated with my desktop.
You may ignore the following rant.
Desktop issues-  halfway through.  Answer is probably a new monitor.  I have a dual monitor setup.  One business color quality analog monitor.  One higher class (but not great) IPS monitor, that is digital.  Samsung 245t.  My operating system / graphics card forces the analog to be monitor 1.  So the computer wakes up to the analog and later makes the digital monitor number one under windows.  I use a gretag eye one calibrator on the digital.
I decided to do advanced calibration.  I wanted a better gamma.  It showed as 2.5.  What could go wrong/?  The process encourages you to manually adjust the monitor to improve performance.  Well, just before leaving, I think that windows / gretag get confused who is one and two.  Not pretty.
Labor Day will be the time to open the box and video card, and windows 7.  The real answer is a new 27 inch and no more dual.
Postby sjordan93436 » Sun Sep 01, 2013 12:50 am
another view with less blue.  I used by the numbers.
gjg_0067sj-jpg
gjg_0067sj-jpg (222.86 KiB) Viewed 46894 times
