Back focus problems
I couldn't make your Link work. Try this one: http://www.johanfoto.com/2013/07/focus-recompose-back-focus/ Nice catch, though, thank you.
This is why you should have the old hash marks on the lens so that you know the effective depth of field and can use it as a tool rather than fall victim to the possible errors.
http://imgur.com/SY7s1lv
Notice the lines on the lens with the f numbers? To use these you focus your camera on the subject, then based on the f number you can shift the focus ring to line up with the front of the depth of field or the back. If you wanted more back depth you moved the focus to the front.
Niels Rasmussen
I agree entirely but there is a trend for removing these from lenses, so yet another simple and practical photographic method morphs into arcane knowledge.
Niels Rasmussen
I have a couple of Nikon pro level lenses but's only on the older AF or MF lenses that you get any kind of DoF scale. There are other little niggly things that bug me by their absence such as a simple screw thread for a cable release. Nowadays you have to buy these incredibly expensive remote cables (or whatever they call 'em). Jeez, I'm sounding like my dad and he's been dead 30 years! To get back to something approaching the original point, I tend to focus manually using the entire viewfinder disregarding if necessary the focus point indicators. If the subject is off centre (nearly always) then I'll focus off-centre. It does help to have a bright screen and fast lenses though!
