If you have the CM 64-bit plugin the hue clock might not be installed.
Mike??
A variation on Varigation
here is my attempt
done in lab
I did find a spot that tolerated the shadow point
used thresholding to do highlight
I used the technique for stretching the curve to increase the colours as well as the saturation slider
what do you think - have I lost any detail in the colour
I lost the hue click when I went to 64 bit too
I've missed it
It would be very much appreciated if it is there in the next update - thanks curvemeister
Hi tina
don't worry about layers they are easy to work with
You'll love them
here is my attempt
done in lab
I've missed it
Hi tina
You'll love them
- webgjg_0111-jpg (303.85 KiB) Viewed 22618 times
