Hue Clock applet suggestion
Doug.S
Postby Doug.S » Mon Aug 26, 2013 4:24 pm
I use the desktop "on top" hue clock now and then.....but,
Now that I'm getting much better at reading Lab numbers, wondering if I can somehow change from RGB mode to Lab mode for the hue clock?
If not, suggest you modify to give user choice (Lab or RGB), or run another applet that does Lab....then could use both at same time?
Doug.S
Postby mikemeister_admin » Mon Aug 26, 2013 7:40 pm
Try this Hue clock
http://www.broadhurst-family.co.uk/xlefteye/MainPages/TheColourWatcherTool.htm
Chris
Doug.S
Postby Doug.S » Mon Aug 26, 2013 9:22 pm
Wow, thanks, does even more than I was looking for.
It runs OK, but if I try to move the window, the applet crashes in overflow...tried as administrator, same result
win7pro x64
I'll play more with it later
Doug
Doug.S
Postby Doug.S » Tue Aug 27, 2013 5:42 pm
Think I discovered 2 things about moving the window:
if I use the menu, move AND do not move the window beyond the monitor it opens in,
then it seems to work OK,
otherwise see attached .jpg of error I get.
cw-error-jpg
cw-error-jpg (13.27 KiB) Viewed 11126 times
Postby mikemeister_admin » Thu Aug 29, 2013 6:51 am
how frustrating Doug, unfortunately I am moving on and taking the site down shortly.
The program works fine for most people I am in contact with, but they all use the Munsell readout as well as standard ones, so see if that helps, or try using one of the older ones on the site.
Zog
