A way to directly convert color negative scan to positive image?
Alex314
Postby Alex314 » Fri Jun 21, 2013 11:52 am
Hello All,
In the past I have scanned several thousand color negatives to 48 bits TIFF images treating them as positives. I used a Minolta Dimage Scan Elite 5400 machine. The reason I didn't use the Minolta software option to scan them as negatives, thus obtaining positive images is that I didn't trust their conversion algorithm. I used Photoshop to do my own conversion, with varying success.
Is there a way to use CM to do the conversion? I have available in nearly every scan a small area of the orange background, and I suspect that using this information, apply the correct gamma and invert the image, this should be possible. But I lack experience with CM to do the "backgroud subtraction" and the conversion. Is there anyone who could help me?
I attach an example (24 bit jpg) reduced to 20% just to illustrate the kind of images I have available.
75-2-0004-jpg
75-2-0004-jpg (999 Bytes) Viewed 35826 times
Postby -default » Fri Jun 21, 2013 3:09 pm
There is a technique that works reasonably well.  Here is a short summary of the technique:
http://www.curvemeister.com/tutorials/what_ails_you/
I'm heading out the door right now but will try to give your image a try later on.
Alex314
Postby Alex314 » Fri Jun 21, 2013 9:19 pm
I'll look at the link you gave tomorrow.
Is it useful to send you the original 48bit Tiff, e.g. as a "WeTransfer" file? That is the kind I want to process.
Postby imported_ganna » Sat Jun 22, 2013 1:57 pm
I had a shot at your image with CM.
75-2-0004edit-jpg
75-2-0004edit-jpg (77.83 KiB) Viewed 35826 times
Alex314
Postby Alex314 » Sat Jun 22, 2013 3:44 pm
Hello Ganna,
Great!
That is exactly as I remember the colors! How did you do it? Please let me in on your secret? Is it difficult? For one I can't find how to invert colors in CM, I had to do it in Photoshop. Lightroom also doesn't have the invert colors function.
Postby imported_ganna » Sat Jun 22, 2013 9:17 pm
Alex, have you done a CM 101 class with Greg? I see there's one coming up soon. Greg will teach you how to do it. I did this in about 4 steps in CM,firstly by moving the diagonal line in the lightness canal of Lab through 90°, so that the lower end is right and upper end left. After that I did a color correction by the numbers firstly through RGB and lastly  a color boost in Lab.
Postby ggroess » Sat Jun 22, 2013 9:28 pm
Alex,
I have created a short video which I will be posting out to YouTube and I'll link it back to the forum.
This is a really good question for Curvemeister users.
It is about 4 minutes...
Postby ggroess » Sat Jun 22, 2013 9:41 pm
Everyone,
Here is a link to the Video describing how to make this conversion in Curvemeister.
http://youtu.be/lrIDpLVpqTk
Alex314
Postby Alex314 » Sat Jun 22, 2013 9:47 pm
Ganna: Yes I did the class several years ago. Also I studied the book Photoshop LAB Color by Dan Margulis, but I don't remember seeing anything in it that would be helpful.
I did try to reverse the L-channel line, but the result is disapointing: the image is totally off color. In a different image a bright red cushion shows as a dark green one. I don't see how this could lead to a more natural image. Shouldn't the a and b channels also be inverted?
Alex314
Postby Alex314 » Sat Jun 22, 2013 10:55 pm
Greg:
This is really very enlightening, your video. I'll come back when I have tried it a few times on different images. Do you think there could be a library file (.acv) made that does the job for a set of color negatives made under the same conditions?
I am ashamed to say that I have used CM very little these past few years - I have to find out all about it again!
Thanks very much, Greg!
