Toroko Gorge, Taiwan
Daniel Zuck
Postby Daniel Zuck » Thu May 09, 2013 1:37 am
Taiwanese landscape
dan
toroko-gorge-taiwan4-image-jpg
toroko-gorge-taiwan4-image-jpg (999 Bytes) Viewed 77577 times
Postby ggroess » Thu May 09, 2013 2:26 am
Dan,
The rocks in the foreground lose shape when you over correct.
Take a look at my adjustments to your posted image and see what you can do.
I have attached the ACV file to get you started...
toroko-gorge-taiwan4-image-lab-acv
(52 Bytes) Downloaded 4115 times
greg04-jpg
greg04-jpg (286.76 KiB) Viewed 77577 times
Daniel Zuck
Postby Daniel Zuck » Thu May 09, 2013 3:01 pm
okay.  First, I redid the whole thing before I read your comments.  Here is what I did.
Dan
toroko-gorge-taiwan4a-web-jpg
toroko-gorge-taiwan4a-web-jpg (184 KiB) Viewed 77577 times
Daniel Zuck
Postby Daniel Zuck » Thu May 09, 2013 3:05 pm
My first rendition is kind of scary, and I wanted a more relaxed view of the scene.  That's why I corrected it.  Your corrections are better than my first rendition of it.
Dan
Postby ggroess » Fri May 10, 2013 12:53 am
Dan,
You might want to start over with this image.
The highlights in the rocks are too far gone and I know there is information in there you can pull out.
I tried to recover it and I had to make too big of an adjustment to the image to save it gracefully.
Daniel Zuck
Postby Daniel Zuck » Fri May 10, 2013 11:57 am
Greg:
I forgot how to incorporate an ACV file into CM.  Please tell me again,
thanks,
Dan
Daniel Zuck
Postby Daniel Zuck » Fri May 10, 2013 12:37 pm
I made corrections to my original version based on what you suggested in your post to me.
Dan
toroko-gorge-taiwan4b-web-jpg
toroko-gorge-taiwan4b-web-jpg (177.62 KiB) Viewed 77577 times
Daniel Zuck
Postby Daniel Zuck » Fri May 10, 2013 1:41 pm
I redid Taiwan 4a.
Dan
toroko-gorge-taiwan4a2-web-jpg
toroko-gorge-taiwan4a2-web-jpg (185.05 KiB) Viewed 77577 times
Daniel Zuck
Postby Daniel Zuck » Fri May 10, 2013 1:47 pm
I noticed the sky in previous post was patchy.  Fixed it.
dan
toroko-gorge-taiwan4a3-web-jpg
toroko-gorge-taiwan4a3-web-jpg (184.75 KiB) Viewed 77577 times
Postby ggroess » Fri May 10, 2013 4:03 pm
Much better overall...
