out-of-sequence purple dog
Daniel Zuck
Postby Daniel Zuck » Thu May 02, 2013 7:35 pm
Worked out kinks in photoshop 10.  Delayed turn-ins because PSE 8 was corrupted.  Sorry for out of sequence work.
dan
dog-for-web-jpg
dog-for-web-jpg (999 Bytes) Viewed 5551 times
Postby ggroess » Sat May 04, 2013 3:09 pm
Did you bring the mask out to the layer in PSE?  if you did then you need to paint out the white spots around the dog so tha tthe purple blotches go away.  If you did not then as far as the mask goes you did well but I would remove the blotches...
