Changed tassels and reflections, but also produced some unwanted changes elsewhere.
(Best I could do tonight.)
red to black tassels
Second attempt.
Changed tassels using LAB a channel mask and desaturating. Apply. Than back into CM to adjust LAB a channel curve to change reflections.
Better colour than first attempt, but less detail in the tassels, which also have a slight colour cast. Tried to fix in RGB, but only created worse colour casts elsewhere.
- red-to-black-tassels3-jpg (308.76 KiB) Viewed 16215 times
If you go into CM and create a mask.
Copy it and paste it to the layer you are working on as a layer mask...Then...
You can then go into CM a second time on the image portion of the layer; and create another mask in CM.
This would give you two masks at the same time since CM will "see" the mask on the layer; and your additional mask inside of CM will effect the adjustments.
