Smartfilter
Postby imported_Tanja » Thu Apr 25, 2013 11:21 am
I have problems with the smartfilter.
When I convert to smartfilter, go to cm, make my changes and apply them, curvemeister is shown as a filter in the layer (first attachment)
But when I click to go back to cm, all changes are gone. I get the original picture (second attachment).
What did I wrong?
untitled-1-jpg-6
untitled-1-jpg-6 (999 Bytes) Viewed 6817 times
untitled-2-jpg-3
untitled-2-jpg-3 (999 Bytes) Viewed 6817 times
Postby ggroess » Thu Apr 25, 2013 12:50 pm
Did you click on the Scroll Icon in CM before closing it??
The scroll I con tells CM it is a smart filter...Again some of Photoshop's connections are "loose" and CM has to be told it is a smart filter in order to act like one.
Shot 1 is before click shot 2 after.
capture-jpg-38
capture-jpg-38 (15.95 KiB) Viewed 6817 times
capture2-jpg-14
capture2-jpg-14 (11.6 KiB) Viewed 6817 times
Postby imported_Tanja » Thu Apr 25, 2013 1:41 pm
Oh, okay! No, I didn't.
Works now. Thank you!
