tiger
Daniel Zuck
Postby Daniel Zuck » Wed Apr 24, 2013 1:13 pm
I did this 'by the numbers' in rgb. Did the contrast pin.  boosted colors in lab
dan
sher-tiger-image-jpg
sher-tiger-image-jpg (999 Bytes) Viewed 16178 times
Postby ggroess » Wed Apr 24, 2013 4:02 pm
You have a cyan problem...
It's actually present in the image you posted but I exaggerated it for you to see easily...
It's pretty uniform so I would look for a better neutral or control the shadows in some way that you like...
capture-jpg-40
capture-jpg-40 (177.89 KiB) Viewed 16178 times
Daniel Zuck
Postby Daniel Zuck » Wed Apr 24, 2013 7:19 pm
tried to  fix them
dan
sher-4x-image-jpg
sher-4x-image-jpg (180.56 KiB) Viewed 16178 times
sher-3ximagergb-jpg
sher-3ximagergb-jpg (190.82 KiB) Viewed 16178 times
tiger-in-lab2-jpg
tiger-in-lab2-jpg (168.53 KiB) Viewed 16178 times
Postby ggroess » Thu Apr 25, 2013 12:59 pm
Great recovery...
Awesome Tiger....
capture-jpg-36
capture-jpg-36 (197.87 KiB) Viewed 16178 times
Daniel Zuck
Postby Daniel Zuck » Thu Apr 25, 2013 8:47 pm
maybe this is better.
dan
tiger-6xx-jpg
tiger-6xx-jpg (187.04 KiB) Viewed 16178 times
Postby imported_Tanja » Thu Apr 25, 2013 10:35 pm
Hi Dan,
what are you doing in the last version. I love the look. Is it a plugin?
Daniel Zuck
Postby Daniel Zuck » Fri Apr 26, 2013 1:05 pm
Tanja:
I don't know.  I tried to fix it with CM in lab then went to the web and found stuff on contrast masking.  There's a photoshop tutorial "Photoshop Tutorials: Lesson 2 using contrast masking" at www.nyfalls.com.  There's all kinds of stuff out there on contrast masking.
dan
dan
Postby imported_Tanja » Sat Apr 27, 2013 7:02 pm
Thanks Dan!
This was very interesting und brings us really good tips from Greg yesterday.
Daniel Zuck
Postby Daniel Zuck » Tue Apr 30, 2013 1:20 pm
Tanja:
You are welcome.
dan
