newspaper
Postby imported_Tanja » Tue Apr 23, 2013 6:06 pm
Not sure, if I understand the exercise right.
First trashholding in L-Channel with endpoints of the histogram, then colors in rgb.
Did I have to do something more here?
newspaper-jpg
newspaper-jpg (999 Bytes) Viewed 9666 times
Postby ggroess » Tue Apr 23, 2013 7:15 pm
Nope Pretty simple idea...just use Lab to clean up the Scanned image...
Keep the color correct and your done...
Postby imported_Tanja » Tue Apr 23, 2013 7:17 pm
Thought color is correct now. Not?
Postby ggroess » Tue Apr 23, 2013 10:26 pm
It is...
It must be a bad translation...No need to change it...
Postby imported_Tanja » Wed Apr 24, 2013 1:47 am
Oh, was my bad translation ;-)
Great. Tiger is waiting now!
