My try at a yellow car
Postby mikemeister_admin » Tue Apr 23, 2013 12:18 am
Hi,
Here is my attempt at a yellow car.  I gave up in LAB.  My hue clock said the car was yellow, but the color looked very strange.  I do not know what I was doing.  When I tried HSB, I eventually got it to work - once I figured out that some of the 'red' had 0 hue..  I used a hue mask that I manually fixed n PS.  I did it in a huury, so there are still some red imperfections and red fringing, but it was not worth the effort to clean it up.
Thanks,
Jerry
i-love-curves-jjw-jpg
i-love-curves-jjw-jpg (999 Bytes) Viewed 5587 times
Postby ggroess » Tue Apr 23, 2013 1:24 am
Nicely done...
HSB is best represented by a circle where Red is at 12:00 o'clock.
Just like the hue clock,  If you take the circle and pull it apart at 12:00 it becomes a line with Red on each end.
