I wonder what the other pins are for? I only used pin 1. Also, what are the SHN pins for. I downloaded them from the forum. They're greg's.
dan
bad skin
Daniel Zuck
Well,
Pin 1 is pretty standard but there are many different hues for skin tones even within the same face. The SHN Skin tones are a part of an entire workflow that is attached to the baby picture.
You can see Tanja's thread about the baby for more examples there. You do not need to take on the advanced workflow...it is there for those who want to try something a bit different.
