Lovely lake picture
Postby imported_Tanja » Wed Apr 10, 2013 12:39 am
Just a short try, because I love the picture and want to try out some stuff from the video (like the bell curve).
Needs much more time. Help everytime wellcome  ;)
2007-11-22_074102-jpg
2007-11-22_074102-jpg (999 Bytes) Viewed 14132 times
Postby ggroess » Wed Apr 10, 2013 1:16 am
not too bad...so far...
no hints yet...Explore and Play!
Postby imported_Tanja » Wed Apr 10, 2013 1:31 am
Alright, Sir!  ;D
Postby imported_Tanja » Thu Apr 11, 2013 11:57 pm
Second try...
2007-11-22_074102b-jpg
2007-11-22_074102b-jpg (302.78 KiB) Viewed 14132 times
Postby ggroess » Fri Apr 12, 2013 12:33 am
Better...I would accept this...
Do you wish to go further??  you could.....
Postby imported_Tanja » Fri Apr 12, 2013 1:17 am
Some tips for that?
Postby ggroess » Fri Apr 12, 2013 1:32 am
Try to open the shadows in the trees without washing out the color...
It's really about where you want it to be...it is a lovely correction...
Postby imported_artmar » Fri Apr 12, 2013 1:21 pm
Hi Tanja,
Your correction looks great.  How did you get so much detail in the sky/clouds?
(Finding that difficult.)
Postby imported_Tanja » Fri Apr 12, 2013 6:20 pm
Hi guys,
Greg, I will try some more the next days.
I love this picture. Where do you shot it?
By the way: Thanks for the information about hk-effect.
Today I found someone, who was able to translate. Still don't got it exactly, but a little idea.
Art,
hm, I'm not that sure. Walks from allone by pushing contrast.
When they went to light, I paint back with a mask and a soft, black brush.
Postby imported_Tanja » Fri Apr 12, 2013 10:17 pm
Hi Art,
now I remember, what I've done with the clouds, after seeing it on the call.
It was a tip from the last conference call to straight up the curve on the bright side, set a point above and flatten curve from there. You remember?
