No tricks, only curves ;)
Problem for me was, that there was no range for contrast. So I use steeper curves on the flower and flatten them on the background. Find no neutral point, so I set one by trying to bring yellow out.
flower
Nice,
Some minor adjustments maybe....
Brighter and more saturated...The neutral you see actually is neutral and it made no change to your image so you did very well on the color. Saturate only until you start to lose detail ten back off to your comfort level.
- capture-jpg-49 (221.27 KiB) Viewed 15795 times
- c01s01-example5-copy-lab-acv
- (56 Bytes) Downloaded 858 times
From the class materials look for the "original image" link under the image Capture.jpg below.
This should download the original file for you.
- capture-jpg-48 (53.06 KiB) Viewed 15795 times
- capture2-jpg-18 (66.77 KiB) Viewed 15795 times
Too much contrast?
It is subjective...to me yes, maybe...
I would grab the L channel at about 75 and brighten it up a bit...I love the Shadows and the highlights are still intact. Seems like the middle is the problem area.
You can choose to leave it alone...It's still in a better place than when you started.
