Boat
Postby mikemeister_admin » Tue Apr 02, 2013 11:53 pm
Hi,
Here is my try at the boat.  Besides lightening the image up, the biggest change was to set a point on the light area of the superstructure and setting the a and b channels to 0 on the assumption that most boats have a white one.  There seemed to be some detail in the windows of the pilot hpuse, but I could not seem to bring any of it out.  Is there any?
Thanks,
Jerry
gjg_0057_small-jpg
gjg_0057_small-jpg (999 Bytes) Viewed 15995 times
Postby imported_Tanja » Wed Apr 03, 2013 12:01 am
Hi Jerry,
new picture! Great! I follow you next days and hopefully can say more then.
Postby ggroess » Wed Apr 03, 2013 12:38 am
There is detail in there yes...
How to get it might be an issue...
greg03-jpg-4
greg03-jpg-4 (102.35 KiB) Viewed 15995 times
Postby mikemeister_admin » Wed Apr 03, 2013 12:47 am
Hi,
I am starting over.  Somehow I loaded a small version of the image.  It made it hard to work with.
Thanks,
Jerry
Postby mikemeister_admin » Wed Apr 03, 2013 1:05 am
It works better with a full size image.  I was wondering how I was supposed to work on one so small.  I have no idea what I downloaded except that it had a _small appended to the name.  Is this better?
gjg_0057_jjw-jpg
gjg_0057_jjw-jpg (221.4 KiB) Viewed 15995 times
Postby ggroess » Wed Apr 03, 2013 11:18 am
It is better a bit flat in the mid-tones but better.  Go after the mid-tones a bit more and pump up the color.
Postby imported_artmar » Wed Apr 03, 2013 12:50 pm
My try:
boat3-jpg
boat3-jpg (314.39 KiB) Viewed 15995 times
Postby mikemeister_admin » Wed Apr 03, 2013 1:26 pm
Another try.
gjg_0057_jjw-2-jpg
gjg_0057_jjw-2-jpg (255.36 KiB) Viewed 15995 times
Postby ggroess » Thu Apr 04, 2013 2:37 pm
Art and Jerry,
I will be looking at these in detail later today...please be patient...
Thanks!
