Contrast Pin settings
Mike, thanks a lot for the Fade slider and the Mask Blur slider. I find it realy handy. One other new feature I would like to see is a separate contrast pin for the a and b channels in Lab. I sometimes set the contrast pin for blue and yellows, but the area I want to pin for magenta and green is on a different part of the curve. When I pin the yellow and blue, it automatically pins the a curve as well. I can go in under edit>reset to remove the pins from the a channel, but when I do the contrast pin on a channel, it pins the b channel as well and mess my adjustment up in the b; which means I have to go back to b and remove the second set of pins manually. It would be nice if one can just contrast pin the a and b separately; it would save a few seconds for a lazy man ;)
