julie lemurs lab
Postby imported_julie » Thu Aug 16, 2012 9:30 am
first  i put shn pins and left curvemeister
Went back in and used the channel to create a in lab
used the channel copy icon annd then pasted this into a hue saturation mask
I then used the brush tool to paint over the grass
the grass was saturated enough as it was
Sharpened but again used a layer mask to reduce sharpening everywhere except around the eyes
So what do you think?
shn1-jpg
shn1-jpg (999 Bytes) Viewed 24993 times
adjustment-layer2-jpg
adjustment-layer2-jpg (999 Bytes) Viewed 24993 times
lemurs-jpg
lemurs-jpg (999 Bytes) Viewed 24993 times
Postby ggroess » Thu Aug 16, 2012 7:50 pm
More complex than I would have done but it gets the job completed...
Works for me...
