julie tiger
Postby imported_julie » Fri Aug 10, 2012 9:28 am
Know this is last minute but I just didn't have much time this week
This was done is lab
followed directions but to get the tiger as saturated as I wanted I made the light patch at the front too yellow
I added a mask and liked the result
needed to watch I did not turn the grass into a toxic green
Grass and tiger were both in the same place on the curve
I had reduced the blue in the rocks but decided to try to get rid of a bit more using rgb
dont think it made much difference
I then used shadow highlight to lighten the darkest parts just a litle
It certainly looks better but looking forward to suggestions for improvements
tiger-lab1-mask-jpg
tiger-lab1-mask-jpg (999 Bytes) Viewed 25418 times
tiger-rgb-reduce-blue-jpg
tiger-rgb-reduce-blue-jpg (999 Bytes) Viewed 25418 times
tigerfinal-jpg
tigerfinal-jpg (999 Bytes) Viewed 25418 times
Postby ggroess » Fri Aug 10, 2012 2:34 pm
Overall he looks better than before but...
Again the shadows are yellow...just a touch...
