A note on Smart Filters
Postby ggroess » Tue Aug 07, 2012 4:57 pm
If you are interested in using CM as a smart filter please let me know.  There is an Icon that looks like a yellow scroll in the area of the program near the configuration wrench.  You must select the scroll in order for CM to "know" that it is being used as a smart layer.  If you forget the scroll the program does not "respect" the smart layer and does not function correctly.
I Just discovered this is missing from the documents for the week and want tyou all to know about it in case you run inot the issue.
