julie bad skintones
Postby imported_julie » Wed Aug 01, 2012 1:36 am
Not happy with the second from the left.
Could not get sides of face to correspond. decided in the end to let highlights be too yellow.
Tom Cruise difficult. hand and face do not match. Makeup?
20-bad-skin-tones-jpg
20-bad-skin-tones-jpg (999 Bytes) Viewed 24518 times
Postby ggroess » Wed Aug 01, 2012 2:39 am
Good job with the noted exceptions....
Tom Cruise is weird in any case...LOL not to worry about him...
The other guy... you might want to take another hack at that one and see if starting fresh give s you a better perspective...Remember to do this in RGB and adjust the image a bit first to make the pin more effective...The closer you are to good color the more effective the skin pins are...they are the cherry on top...
