Fruit Vendor
This one gave me some grief - hours!! I set two neutrals but couldn’t get anywhere until I set a highlight on the whitest light. Then it clicked into place, or at least it looks better. I didn’t touch the curves at this stage but I will revisit this image when I have time.
- fruit-vendor-rgb-snap-jpg (999 Bytes) Viewed 6092 times
This one is all about compromise....
The white light is good and in order to get this one in a better place you need to watch the Skin tones in the image as well. This is about the toughest image in the course so don't give up on it there is a lot to learn here...
You are off to a good start...Set a Hue clock on the skin tone and see if you can change the Green and Blue in the area of the skin without upsetting the rest of the image. Also add a touch more contrast on the Master channel...
