Greetings!
Postby ggroess » Thu Jul 05, 2012 6:27 pm
Class will open on the 8th of July 2012.
I want you to know that the first week can be confusing and intimidating and sometimes downright scary if you are new to image correction using curves.  We will do the best we can to get you up to speed; but some of the experienced users might be putting some stuff out here that makes little sense at first.
Please...in the words of Douglas Adams...."DON'T PANIC!" http://en.wikipedia.org/wiki/Douglas_Adams
The first week is kind of free form and we allow all forum members to see into the class so there most likely will be a very interesting discussion that usually helps all members.
After the first week we will "close the door" so to speak and get down to the curriculum written by Mike and myself.  The curriculum is as shown with some minor additions and hopefully tons of discussion.  Our experience over the last 4 years teaching the class has shown that the more discussion that occurs the better everyone in the class learns the materials.  It is possible to sit on the sidelines and take the class without posting your images; but we hope that you will post and comment on each others work. We will make every effort to keep the postings friendly and encouraging.
Do not be afraid to ask questions.
Our goal is to add Curvemeister to your everyday work flow and make it one of the first tools you look for in your image correction...we will do that by showing you how powerful and hopefully easy it is to use.
If we fail to answer your questions poke us in the side...We'll do whatever it takes.
Thanks for choosing the Curvemeister plug in and for being willing to explore image correction on our forum.
Mike Russell
