Hi guys! Today I received Photoshop CS6 in the mail, so I installed it and when I installed Curvemeister 3.41 (64 bit), it didn't show up in Photoshop, even though the install seemed to go okay.(I'm running Windows 7 Ultimate 64 bit). I figured that I'd just copy the 8BF file from the Curvemeister folder and paste it in the Photoshop/plugins/filters folder, but there is no filters folder in CS6, so I just pasted it into the plugins folder and that did the trick.
If you don't know where the Curvemeister folder is, go to C:program files (x86)curvemeister3 and click on curvemeister 3. There is a file called curvemeister 3 that has as it's file type 8BF. Copy this file, then paste it into the Photoshop CS6 plugins folder.
I just thought that I'd mention this in case anyone else had a problem installing Curvemeister into CS6. :)
Installing Curvemeister 3 into Photoshop CS6
When I downloaded and installed Curvemeister 3.4.1, I couldn't find it in CS6. The install said that the installation went okay, but I wasn't able to find it so I just copied it to the plugins folder and it worked okay. After reading Greg's post, I decided to copy it again and post it into the folder that he mentioned.
It always bugs me when they constantly change folders in a program. In Photoshop, it was always the plugins/filters folder....now it's under the "Required" folder.....as if they just want to confuse people. ???
Return to “Help Me! I'm new and I need some help”
