Adobe has opened up access to the CS6 public beta.
http://labs.adobe.com/technologies/photoshopcs6/?PID=552179
Photoshop CS6 Public Beta
CM runs just fine under CS6. The install path is different to the plugins folder.
CM's 8BF file needs to go into :
C:Program Files (x86)AdobeAdobe Photoshop CS6RequiredPlug-InsFilters For 32 bit
C:Program FilesAdobeAdobe Photoshop CS6 (64 Bit)RequiredPlug-InsFilters for 64 bits.
If you have it installed just copy the 8BF file from the current install into the folders listed above and you should be just fine...
