Daryl - Week 5 Image 1
This is the forum board for the Jan 2012 CM101 class
Postby ggroess » Fri Mar 09, 2012 4:05 pm
Daryl,
The give away here is the Red shadows.  When you create the mask leave a bit of the shadows open and try to make the shadows neutral.  I think we'll probably cover this one in the discussion so I'll wait to post a solution for you until after the video is up.  Give the masking another go and see if you can hold the shadows.
greg03-jpg-7
greg03-jpg-7 (999 Bytes) Viewed 16906 times
Return to “Curvemeister 101 - January 2012”
