Downsampling with ImageMagick
pictus
Postby pictus » Tue Jan 10, 2012 7:23 am
Download and install ImageMagick:
http://www.imagemagick.org/script/binary-releases.php#windows
http://www.imagemagick.org/script/binary-releases.php#macosx
http://www.imagemagick.org/script/binary-releases.php#unix
Download and unpack into your DeskTop
http://dl.dropbox.com/u/4686872/Pictus-resize2.zip
or http://www.mediafire.com/file/w47dqrjrzds3ffy/Pictus-resize2.zip
It contains some BAT files
To resize, just drag and drop any image over one of the icons in the DeskTop
The result is better than the other programs as it is free from moiré and gamma corrected during resize.
The original image http://www.mediafire.com/?49ahiwm5ukfu6c9
More details:
ImageMagick resize http://www.imagemagick.org/Usage/resize/
ImageMagick and USM http://redskiesatnight.com/2005/04/06/sharpening-using-image-magick/
Resize and gamma http://www.4p8.com/eric.brasseur/gamma.html
The BAT files are versions from http://www.openphotographyforums.com/forums/showthread.php?t=14947
Postby ggroess » Tue Jan 10, 2012 10:54 pm
Um...wow that is a lot of stuff to absorb....
Do you have any further examples?  I'd like to see the sharpening side as well as the downsize....
pictus
Postby pictus » Wed Jan 11, 2012 10:06 pm
Only the stuff about gamma and resize http://www.4p8.com/eric.brasseur/gamma.html
I did the final update, I guess now looks OK :)
pictus
Postby pictus » Wed Aug 01, 2012 9:46 pm
New version!
http://dl.dropbox.com/u/4686872/Pictus_resize_D.zip
-4 batch files, 640, 800, 1024 and 1200
-Each file will create 2 versions from 3 algorithms, making 6 for you to choose. :)
-It is from a soft to sharper in gamma 1 and sRGB, all in EWA(Elliptically Weighted Average)
-You can edit the batch files to enable the orthogonal versions or the other algorithms or disable the unneeded...
Return to “Software”
