This online session includes some unique "red burn" slide restorations by Greg, and an Lab correction by Mike, and a few minutes at the end playing with Photoshop's Merge Layers command.
First rough cut available:
http://www.youtube.com/watch?v=3yCBsUmXefk
If the above link breaks, please refer back to this page for a link to the newer version.
Mike and Greg
Curvemeister online session Oct 28, 2011
Here are the Red Burn ACV files.
- red-burn-rgb-acv
- (66 Bytes) Downloaded 706 times
- red-burn-rgb2-acv
- (66 Bytes) Downloaded 786 times
I have been thinking (always dangerous). Perhaps if you had a topic posted before and after you might get more viewers and more non- CM ers. E.g., "fix a mixed color cast with CM" . That could lead off and then do another image or two.
This is not a criticism, just trying to be helpful. I am sure you can find volunteers with bad images....
Users browsing this forum: No registered users and 61 guests
