10-21-2011 video is available online
Postby -default » Sat Oct 22, 2011 12:15 pm
The online session for 2011-10-21 is available here:
http://curvemeister.com/video/mike/2011-10-21-CmSession/2011-10-21-CmSession.html
The session is also available on youtube.
http://www.youtube.com/watch?v=S_L-_N1ZHco
  The youtube link may change when new versions of the same video are released.
The first link is preferable because it is higher resolution.
Be sure to full-screen the video for max resolution.
The images I used for the session were kindly provided by Lowell, and are attached to this post.  I also attached the curve acv file for one of the images.
_dsc6661_0002-jpg
_dsc6661_0002-jpg (999 Bytes) Viewed 11083 times
_dsc7719_0026-jpg
_dsc7719_0026-jpg (999 Bytes) Viewed 11083 times
_dsc7759_0066-jpg
_dsc7759_0066-jpg (999 Bytes) Viewed 11083 times
_dsc7719_0026-lab-acv
j2e4a8n
Postby j2e4a8n » Tue Oct 25, 2011 2:44 pm
You talked about the Delta i feature.
What about the S/N feature in the sample section?
JPD
Postby -default » Tue Oct 25, 2011 5:50 pm
S/N is signal to noise: the average value of the sample divided by the standard deviation.  It is used for analyzing the amount of noise in the image, and for calculating the resolution of a optical system.
Users browsing this forum: No registered users and 73 guests
