Lesson 2-Submission 2
This is the forum board for the June 2011 Curvemeister 101 class.
Postby mikemeister_admin » Sun Jun 19, 2011 10:44 pm
What do you think, better?
Lowell
carousel-2-jpg
carousel-2-jpg (999 Bytes) Viewed 19759 times
Postby ggroess » Mon Jun 20, 2011 2:26 am
The color is reasonable now take the image back into CM; open it in LAB; and add saturation within reason...
When I did it; the image holds up fairly well...
While you are in LAB try to recover some of the highlights as well.
You are getting there...don't worry...
