Pins problem
Niels Rasmussen
Hello everyone. I recently updated my CM to v3.3.5 and (aside from some teething problems) everything works fine. However, I don't seem to be able to save my pins. I'm entering them exactly as I did on my old version, but when I exit CM and then re-open they disappear! Hope you can help. Many thanks, Niels Rasmussen
Niels Rasmussen
Hi Mike, the only pin file I could find was in C/documents and settings/all users/application data/curvemeister.com/curvemeister3 elements/library.... Is this the right place to look? I couldn't find anything in program files. The file was marked as read only, but when I unchecked the box and hit apply, it just reverted back to 'read-only'! I am named as administrator for the PC so I'm not sure what's going on. Anyway, thanks for the reply. I'll keep trying. Regards, Niels Rasmussen
Niels Rasmussen
no apology required...I have been known to answer to many different names...
On my XP system the pins files are located in...
C:WINNTProfilesAll UsersApplication DataCurvemeister.comCurvemeister_3Swatches
If you are the only user your path may start out differently but then should follow the path from "Curvemeister.com" forward to the files. Your path may show Curvemeister_3_Elements instead of the Curvemeister_3.
Return to “Help Me! I'm new and I need some help”
